21 - 30 of 30 Posts
2004 SRT-4
ST Coilovers makes a single set for both regular Neons and the SRT-4, however dispite adjusting them 10 million times I could not get them to stop rubbing with stock wheels / tires. Wider / larger wheels and tires were even worse.
Are you talking about coilovers? (ST-X)
If so.....rubbing on the fenders or what? Were you too low?
I've had those before (on a different car), and they're not bad since they're made/developed by KW (sorta)....but I was trying to keep this car stock-ish.
Yep, those are the ones. I had them at the highest height settings and they were rubbing on the inner fender metal rib on tight cornering at intersections where the intersecting roads were not level.
2004 SRT-4
At their highest setting they would rub? :unsure:
Any pics of the car where you have them set now, if you still have them?
Did you pair them with stock upper mounts too, btw?
No longer on the car; I'm back on stock struts (brand new top-2-bottom) and Stage 1 springs.
When I had the STs on they were on new stock mounts as well. They come with their own rotation bearings IIRC.
Stock neon struts with neon springs will work in a pinch,only issue is lower ft. Spring perches are very close to 17in. Factory tires.
I had 4 neon struts and springs on my car for a while......it actually handled pretty damm good and rode better as the neon springs have many more coils.
  • Like
Reactions: snobrdrdan2
2004 SRT-4
Well that’s something to think about!
good info/thanks for sharing!
2004 SRT-4
FYI/NEWS FLASH!
ModernPerformance has them in stock again!....I just ordered a set the other day (and just received today):
21 - 30 of 30 Posts
