With Stage 2 being "re-released" and many folks on the forum finally getting them into their hands, I thought I might share a few observations and tips regarding the installation in the hope that it may assist others.
1. Pulling the fuel pump relay on my car prior to removing the fuel line was unnecessary. The car wouldn't even start with it pulled. Let the car sit overnight, as I did, and just put a rag under the connector to catch the little bit of gas that dribbles out. There will be fuel in the rail, so if you tip it, it will pour out. Pull the rail and injectors out as one piece, fit the new injectors to the rail, then install as one piece (don't forget the retaining clips!)
2. As Lucy also mentioned in her write-up, I couldn't get the PCM and bracket in as one piece. I took them out separately, too.
3. You need a Torx#20 screwdriver to remove the MAP sensor from the manifold.
4. The TIP sensor was the hardest thing to get out, believe it or not. I had already reinstalled the airbox after changing the PCM, which in hindsight was a bad idea, but I was too lazy to take it back out. I just bent the bracket down to finagle the sensor off, and bent it up to remove the white vacuum line. I reversed the process for the installation of the new TIP. BTW, if you can fit a screwdriver in there, the bracket can be pried out and the popped back in when done.
5. Wastegate wasn't tough, as I had already removed/replaced the top heat shield when I did my O2/exhaust install a few months ago and I didn't tighten them to death like the guy at the factory. I had to adjust my wastegate to get the proper 4mm preload on the wastegate arm. Just make sure when you put it all back together that there is no interference in the wastegate arm's movement.
6. I did the install in the following order and it took me about 3 hours taking my time (it was nice outside): injectors, PCM, MAP, TIP, wastegate.
The car actually seems to idle smoother, spool up faster, and PULLS GREAT!
The Mopar BOV is noticeably louder, too. In the brief time I've driven it, I can say that it was well worth the $$. :thumbsup:
