1 - 10 of 10 Posts
at 17 psi range (plus or minus) on the egt never gets above 1400, rarely even that high. if you get on say...80% throttle and the boost goes way up the egt climbs to near 1500 (i didnt keep doing it cause i didnt want to do anything bad)
wot seems fine cause fuel dump but lots of boost without wot=high temps.
with the egt right AFTER the turbo what kind of TEMPS can i go to and stay SAFE? (hector?)
thanks! and i hope this helps some people.
for the EGT unless you get a weld in you're not putting it before the turbo. even then i dont know cause its a little shallow and the weld-ins i've seen are kind of long. if you do it after the turbo you can do a clamp in pretty easy. get prolly 5 bits that lead up to the size you need. start the car, start drilling. once yer in shut the car off. let cool for 2 hours. come back, clamp in the probe, put the shield back on etc etc and yer done (more or less)
Actually, this here is the best way to install it:
Drill into the manifold and then thread it with a 1/8NPT Tap. SCrew in the bung, then insert the thermal couple and tighten the back nut and wala.
Thats how the EGT setup is on the GReddy , BLitz and HKS units. AUto meter and some others have a clamp type setup where they use some type of hose clamp that holds it in place. Im not to fond of that setup. NOt as clean of an install.
much appreciated. i'm gonna make my way up to the tampa are one wknd so i can watch & learn instead of asking all thes basic questions. 'preciate everyone that's giving advice to the uninitiated.
1 - 10 of 10 Posts
