· Registered
Ok, so I have a serious rookie question. I know I have seen pics of people with the fogs and headlights on, but somehow I am overlooking the switch or something cause obvioulsy they go out when the headlights come on but how do you get them to stay on with the headlights? ...and no, I havesn't looked in the manual yet. :frogtongu
· Registered
You turn on your headlights, then with the same switch you turned your head lights on with, you just pull out the knob to the left. Fairly simple.
But I have a question, do you want to always have your fog lights on when your headlights are on? Because if you do, why? If it isn't foggy/raining/snowing, they don't do you any good and just put more strain on your alternator.
· Registered
Thank you sir, and no, I don't drive with them on, simply wanting to know how to :thumbsup: . Next question I would have is what are you supposted to have for stock boost levels? Mine seems to spike to 10, then hold at like 7, but sometimes just goes only to 7psi. I thought stock spiked at like 14, or am I wrong? Thanks again.
· Registered
In 1st you'll only see 7-8 if memory serves me correctly. In 4th or 5h gears, pending on weather and a few other factors, you should see anywhere from 11-14 as your spike. If you've just floored the car several times for example, then the computer may cut boost in 5th down to 10-11 because of things like heat soak.
I'm assuming this is on a stock srt4 though, if you have S1 you'll see higher boost levels.
