I am trying to get my son's 05 acr started,the security light is off,I have fuel pump primes,fuel pressure cranking,the tach moves when cranking,I have voltage at the coil and injectors while cranking but no spark or injector pulse.the cam and crank sensors are both new.my son wrecked his 04 srt4 and I swapped every wire the dash everything from his,it ran before I pulled the motor out,the only thing that has not been replaced is the stage 2 pcm.any thoughts,?. I think the pcm is bad ,thank you for your help
