· Registered
Glad to see a nitrous thread! Questions:
Why wet perfered over dry?
When using the WOT switch, how does the system work? When should you arm the system?
Give any other detail that may help. Thanks.
· Registered
with a wet kit you tap fuel directly off of your fuel rail.
with a dry kit you cannot get more fuel to the engine!! this is because of the return-less system that we have. Normal on a dry kit you use the fuel pressure regulator to BOOST pressure to you fuel injectors therefore adding fuel. again, we dont have a fuel pressure regulator so it doesnt work with this car.
· Registered
BUT, if you buy a wet-kit, you'll want to buy the parts neccesary to put it on. Other than a fuel pressure regulator I think you need some thingy to hok the tubey into the fuel rail; i.e.: a new fuel rail?
· Registered
WET. I think the reasons are obvious (i.e. fuel).
Basically with a WOT microswitch, that very microswitch is hooked up to spray when you hit WOT (i.e. pedal to the floor), once you've activated/turned on the system. You can arm the system whenever you want, so long as you are careful not to hit WOT at too low of an RPM. I think the general rule is not to spray any lower than 3-3.5k RPM's.
General rules are: Don't spray in 5th. Don't spray for longer than 15 seconds (who does that anyway? LoL). If you're launching w/a WOT system, careful not to hit WOT upon launching, you'll spin for days.
