1 - 11 of 11 Posts
hey guys, i need some help if possible. today i was driving on my way to school when i came behind this guy and wanted to pass. i was in 4th gear at about 3k rpm's. i down shifted to 3rd and hit about 4500 and heard something pop/blow off (not the bov). next thing i noticed it was all wierd. i coudlnt boost as high as i usually do. i used to spike at 18 and drop to 15, now i spike at 15 and drop to about 11 or 12. so im not boosting as high. also whenever i try to brake i can still brake but i hear this loud noise...a very loud screaming type noise and its like a pulsing kinda like its in one spot on the brakes (or something like that) because it doesnt scream through the whole braking. this is odd. i suspect its something having to do with the vaccum, but then again im not car/turbo expert, so any help would be appreciated
Check your hoses. Sounds like something popped off and is now rubbing somewhere.
Have you popped your hood yet?
power brake booster line, big black vac line leads into the black dome thing behind the master cylinder on the firewall.
yes i have looked under the hood and i didnt really know where the solenoids to the vac lines were, also i checked that fat black brake line and didnt see it popped off anywhere, are you sure about this, ill double check it again tonight reguardless
if your car is running(idling) and your sitting in it with windows down and hit the brake do you hear a noise?/feel any weird change in idle rpm?
also hrrrrrrrrrm run car for about 35-60 seconds , shut it down , then push down the brake pedal , should be fairly easy to push 1 1/2 - 2 times <--based on vac being present in the booster which is kept in by a check valve , if the pedal is hard (initially should be soft <not spongy of course lol , should get hard after the 1 1/2-2 pumps), there is a prob there.
once you've done this test , pump the pedal a few more times til it's extremely stiff (with the car off) , then , with your foot applying pressure to the hard pedal , start the car , once running , the pedal should drop toward the floor , if this doesn't happen , then you've got a problem there.
don't know if this will help , but it'll rule out a booster and or check valve problem and you can move on to another theory
Discussion Starter · #11 ·
ok i did all of what you said and they checked out...no probs there. i got the boost back up to specs, but the brakes are still funny making that loud screaming noise whenever i try to brake. btw, this is only when the car is warmed up
1 - 11 of 11 Posts
