1 - 7 of 7 Posts
I ordered a new IAT sensor and IAT pigtail. How how the hell do I wire the pigtail pack? It came with 4 wires and the pack. Now im lost.
Is there any how-to to wiring that pack????
help greatly appreciated! :eeeek:
tinctorus said:
where are you at in florida maybe i can help if you are close man
North of delray beach. about 30 mins from coral springs. i will take pictures of what I got in the package. Look at the arrows. I assume those both go together, but there is a red rubber piece with a small whole. Do I force it through there so the pins contact or no? The other side I suppose I splice and solder together. I just dont want to break this. Freaking 30 bucks and 1 day order. some bullshit
those are the pins when you push them into the wholes they clip in and shouldnt come back out
i dont know why they gave you 4 wires but they will just click in
They look to be two different gauge wires. Use the two that are closest to the size of the wires on the harness. Make sure you solder them, do not use those crimp things, and use the heat shrink tubing. Good luck!!
Oh ya, make sure the blue clip is not engaged when you put the terminals in.
wow very easy. blue clip was still out. I put it all together now, and its one piece. I was just a bit unsure and thought I'd get a second opinion first.
I got it from here - got a sick soldering gun, and heatgun. =)
thanks for the answer guys.:clap: :clap:
1 - 7 of 7 Posts
