do not turn car on
think about it block the intake the turn the car on makes no since what so ever just put the tester on the put air in the lines and check for leaks
thats all there is to it
DONT TURN CAR ON
only time you turn car to ON POSITION is when you have a stock type BOV... you dont actually turn the car on. just on position. you wont need to even do that because of ur BOV.
yes just on position and if you still have "factory boost leak" black line to intake cap/plug that also. if your pcv is leaking like it prob will be get the ptperformace check valve and stop that leak it can be from 1-2 lbs.
