1 - 2 of 2 Posts
What does it actually control? the redline boost or actual boost? right now i'm not sure what the wastegate is set too. So if i set the waste gate to say 15lbs instead of the recomended 12, will i need to set the boost controller at all?
My first run i was hitting a solid 17 possible 18 getting a real neat woosh noise, but i had to feather the gas or i would hit the fuel cutoff.
Today after backing the boost controller down i'm getting 14lbs. Should i up the boost controller or set the waste gate?
It adjust the spring tension on the wastegate. Boost controller controls the pressure source to the wastegate.
Set the WGA to 13psi or so, then adjust your boost controller up to your desired setting.
1 - 2 of 2 Posts
