This morning I realized that TurboXS is only a couple of miles from where I work and I've been looking for a dyno, so I called them up. It was my lucky day... they are pretty much booked up for dyno runs until July, but someone cancelled today and they were able to take me in right away. I didn't have a chance to go home and install my race pipe, but with my new Greddy e-01 EBC I wanted to make sure I wasn't overboosting so I decided to take the slot anyway to check the A/F ratio.
I met Nathan and Phil at TXS, and they were both very cool. They hooked me up, and with 17 psi boost I got over 260 HP! They were even surprised, because up to that point they haven't been able to get that much power from their project car either.
It turns out that the way I have the EBC connected, T-eed into the existing compressor outlet vacuum hose port, is a big deal. Apparently, the car's stock boost solenoid needs to see pressure, or else the ECU compensates and all you get is more torque, not HP. (I might have the technical explanation wrong, but I'm sure Nathan can correct me if I'm wrong.) After I left, they hooked up a boost controller to their bone stock SRT-4 the same way, gave it 17 lbs of boost and got the same numbers, or close to the same numbers, as I did.
The A/F chart shows that the car starts to go lean at around 4800 RPM, ending up around 12.0. They said that showed I was running out of fuel due to the small stock injectors. But we didn't hear any detonation and they thought it was fine. For the street they advised that I should keep the boost around or under 16.5 psi.
So the good news is great numbers! The bad news is that compared to their car, my ATP Stage I downpipe+cat didn't seem to make much of a difference. But they've squeezed me in again next Saturday, the 26th, for another set of runs, this time with my racepipe installed.
I spent some time talking to Nathan and Phil afterwards, and asked them about their plans for the SRT-4. They will be coming out with lots of stuff, including their UTEC engine management system and a bigger Garrett turbo, in around 6 months. They demo'd the UTEC for me. That thing is awesome. I'm definitely getting one! They think they can get the SRT-4 up to around 400 HP.
Here are my charts. The high numbers are mine. The low ones are the baseline for their project car.
It was around 50 degrees, 60 % humidity. They did spray the FMIC with water before each run. They did use a fan. The numbers are actual HP, not SAE corrected. My mods include:
ATP Downpipe
ATP Hiflow Cat
Greddy Profec e-01 EBC
DR Motor Mounts
PVO-style "Hood Mod"
K&N Drop-in Air Filter
ATP UPP + HKS BOV
Blitz DTT-DCCII Turbo Timer
HP vs Torque:
http://import.h8rs.com/drolander/TurboXS_SRT4_Dan_HP.PNG
A/F Ratio:
http://import.h8rs.com/drolander/TurboXS_Dyno_Dan_SRT4_AFR.PNG
Boost:
http://import.h8rs.com/drolander/TurboXS_Dyno_Dan_SRT4_Boost.PNG
ATP Downpipe
ATP Hiflow Cat
DR Motor Mounts
ATP UPP + HKS BOV
HP vs Torque:
A/F Ratio:
Boost:
