1 - 12 of 12 Posts
This is for my dodge avenger. I got the extra injector bungs welded onto the itake manifold for my 8 injector setup and im going to try and run the srt oil pump and pan setup.
Looks good sofar. Just a quick question though...what's the point of having 8 injectors when all the other 2.4s I know of (and 2.6s) can make power just fine with 4 injectors?
I dont have the same ecu as the srt. The srts have the NGC computer. My set up is more like the portfueler for the srt4 but with a lil bit more controll. so every things work like the factory intended until boost kicks in then the other injectors take over. Thats as simple as i can get it but you know the deal.
SpeedEuphoria said:
also better idle quality and off boost mpg
It seems the best way to go for me with out going stand alone. I almost went megasquirt but i didnt want to rewire every thing and have codes so I went 8 Injectors simple and eficient not to get my oil situation sorted out. Any body got some sugestion on my set up.
The oil pan has been choped and hack the same way a stratus one would be for the original swap. The oil filter assembly has been removed with AN fittings taped in for a remote oil filter. I have and under drive pulley but I guess its bad for the srt. So i went with the srt pump combo just so i can keep my stock balancer and better oil flow pics up tomorw just finished it when I got my pump and pan from SMOKINSRTBOI.
1 - 12 of 12 Posts
