R8V3N said:
I just cerently bought an 05' SRT4, and dang this car eats a lot of Gas. I thought it was suppose to be 22 on City and 30 on Highway. Imagine me putting full tank of gas, then in less than 200miles its about 3/4 of the way already. Is there anything wrong with my car or this is just normal, the gas is really getting killed fast. By the way my car has 700+ Milage, and driven normaly at the moment. Thanks guys.
Thats normal. I get around 20 mpg, 18 if I get on it alot. I get about 180 miles to the 1/4 full line. After that you can get another 50 miles pretty easy. When the gas light starts blinking at you, consider yourself warned.
I fill up at 1/4 tank, and its only about 9 to 9.5 gallons. The car gets reasonable gas mileage. Keep the engine in the 1800 -3200 rpm range and don't depress gas pedal more than a hair. (stays out of boost) You might get 24 -30 mpg.
If the cost of gas is an issue, I would suggest getting a different car. I knew in advance the amount of $$$ I spend on gas was going to double. I was getting 29mpg in my old car on 87 octane. Now I get 19 with 91 octane. The price you pay for boost... its so worth it.
If you really want good gas mileage put 87 in your tank. the PCM will pull boost and timing so quick you'll have no option but to go slow and use less fuel. I *HIGHLY* reccomend NOT doing this though.
