1 - 19 of 19 Posts
Hey James,
Can you get me prices for both of those parts and shipping to 48310. Thanks!
5183442AA - wiring harness repair kit
05073045AB - Multifunction switch
This is the second time in 50,000 miles the MFS has failed on my car. First time the dealer replace it under warranty, and 2 days ago the connector pretty much melted in the MFS. Have you heard of any TSB's regarding this issue?
Thanks and Happy New Year,
Kris
krispl said:
Hey James,
Kris
5073045AB multifunction switch $44.53
If gray 20-way Multi-Function Switch connector is also damaged and requiresreplacement, wiring kit 05183442AA is available, without replacing the entire wiring harness
05183442AA multifunction switch connector repari kit $42.52
No TSB's... no recalls, and I haven't checked yet, but I don't believe there is a star online case.
The only help is that they give us a connector part number when ordering the switch.. as the connector is shown as nonavailable when checked through normal channels.
No problem... Becky should get ahold of you shortly.
I shot Becky and email to find out for me... the computer system is down for me to check where it's at. I'll get back w/ you shortly.
:bump: for parts info
Discussion Starter #8 (Edited)
Thank you guys, I got it today!!!
Now I've been looking at wiring diagrams and I'm going to add in relays to the high and low beam circuits to make it more reliable and to prevent this from happening again.
I don't have a 03 wiring diagram, but in the 04 service manual they clearly show that there should be a high beam relay and a low beam relay installed in the fusebox. This must have been a changeover from 03-04, and that would explain why no one with an 04+ car is having this issue.
What puzzles me is that I checked a local 04(built 3/04) and and he also didn't have relays:stab:
Would you mind checking your 05 acr to see if it has 2 relays installed in the fusebox on the drivers side. They are at the bottom of the fusebox. This diagram of the fusebox is upside down:
Sure... next time I'm near the car I'll check it out. Anyone else?
is there i a diagram for which wires go in each numbered spot? i fucked it up and now things go off like pressing the brake is turning signals :stab::stab::stab::stab::stab::stab::stab::stab::stab::stab::stab::stab:
does anybody know where i can get a diagram!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
MULTI-FUNCTION SWITCH - GRAY 20 WAY CAV CIRCUIT FUNCTION
1 L50 18WT/TN (EXCEPT EXPORT) BRAKE LAMP SWITCH OUTPUT
2 L61 18LG LEFT TURN SIGNAL
2 L61 18LG (EXPORT) LEFT TURN SIGNAL
3 L6 20RD/WT FUSED IGNITION SWITCH OUTPUT (RUN-ACC)
4 L63 18DG/RD LEFT TURN SIGNAL
4 L63 18DG/RD (EXPORT) LEFT TURN SIGNAL
5 L62 18BR/RD RIGHT TURN SIGNAL
5 L62 18BR/RD (EXPORT) RIGHT TURN SIGNAL
6 L60 18TN RIGHT TURN SIGNAL
6 L60 18TN (EXPORT) RIGHT TURN SIGNAL
7 Z3 20BK/OR GROUND
8 E19 22RD PANEL LAMPS DIMMER SIGNAL
9 L7 18BK/YL HEADLAMP SWITCH OUTPUT
10 - -
11 A15 18WT FUSED B(+)
12 L38 16BR/WT (EXPORT) REAR FOG LAMP FEED
13 L4 14VT/WT (EXCEPT EXPORT) DIMMER SWITCH LOW BEAM OUTPUT
13 F61 16WT/OR (EXPORT) FUSED B(+)
14 F39 14PK/LG (EXCEPT EXPORT) FRONT FOG LAMP SWITCH OUTPUT
14 L39 16LB (EXPORT) FRONT FOG LAMP SWITCH OUTPUT
15 - -
16 L4 12VT/WT DIMMER SWITCH LOW BEAM OUTPUT
17 L33 14LG/BR DIMMER SWITCH HIGH BEAM OUTPUT
18 F3 12LB/OR FUSED B(+)
19 F3 12LB/OR FUSED B(+)
20 F33 18PK/RD FUSED B(+)
Wow, dead bump =].
My cousin has a 2001 ACR that the lows appear to have gone out on, but the high beams still work. I'm thinking it's the same problem here, seen lots of people reporting it.
What's the price for both the repair kit and the switch? $87?
current pricing:
1 5073045AB Multifunction Switch 62.16
1 5183442AA Wiring Harness Repair Kit 44.84
+ shipping
subscribed and probably ordering in the next few days. If i pop that steering colom cover off will i be able to tell that one or the other is melted or is it just common practice to replace both at the same time?
-My headlights only work on lhigh beam, no fog lights, gauge interior lights like gauge cluster are intermitten. Sound like the MFS?
if the wiring is melted or abnormal in any way, do both. IF the wiring is fine, just mfs for sure.
i will check tomorrow and then order, i didnt see it on your website, should I PM you my order info or email Becky?
email is easiest!
Hey could you please email me at [email protected] on this.
1 - 19 of 19 Posts
