1 - 1 of 1 Posts
Some combustion chamber designs, such as rotary motors, require that the spark plugs have the ground electrode placed to the side of the center electrode rather than below as on a traditional plug (see photos below.) This firing tip design tends to erode the tip of the ground electrode faster than a traditional plug, and as erosion at these points creates a larger gap between the center and ground electrodes, plug misfire will occur. Thus, by having more ground electrodes, you extend plug life. It is important to note that multi-ground does not mean multi-spark - electricity follows the path of least resistance, there will still only be one spark at a time. Therefore a multi-ground plug will not perform any better and may actually perform worse than a traditional plug, unless the engine is designed for a multiple ground plug.
1 - 1 of 1 Posts
