does anyone know if when installing the MPx catch can do you have to remove the stock airbox to fit it or can you still use the stock airbox? i might just get a CAI but if i can keep the stock airbox id like to elongate having that as long as i can, thanks for any help.
I put mine in the driver's side fender and added a drain plug to the middle of the bottom. It is easy to get at when I want to drain it and that makes it the lowest point in the system.
Do you happen to have any pics or something if you don't mind?
You can still reuse the oem air box just make sure that there is no vacuum leak within the fitting of your catch can.
