1 - 20 of 23 Posts
· Registered
Alright, i am looking to get rid of my HORRIBLE wheel hop, but i also do not want vibrations. I know it is virtually impossible to get both perfect, but what motor mounts do u guys recommend? What about just filling in the stock ones?? What do u think?
· Registered
I heard that the Exhaust Depot is selling an upper motor mount that eleminates wheel hop and there isnt much vibration...I would check that out, I am just waiting for results before I get it!
· Registered
19 psi : stock said:
first thing i put in was prothane inserts, they completly took away my wheel hop.....on the stret that is... the track is anther story
what do u mean it took it away on the streets but the track is a different story... what is the difference?
· Registered
Look in my section for customer results under the section where i introduced them.
I currently have 0 in stock right now.
· Registered
Discussion Starter · #8 ·
i am afraid to get it because $160 for just 1 motor mount just seems like an insane thing to do. i wish there was some way to test it and see if i liked it, and if i didnt i could return it or something.
· Registered
http://jlmmotorsports.com/4.php?ID=238&Year=&Model=SRT-4
Just like it says , it eliminates about 90% wheel hop , I tested mine at the track and it does eliminate about 90% and I don't feel any vibration inside the car while driving either.
· Registered
That's the JLM mount. I'll give a review after I get it and test it.
· Registered
Discussion Starter · #11 ·
when are u supposed to get it?
· Registered
He will receive it on Oct 6th...... I can see the future LOL
· Registered
Discussion Starter · #15 ·
i am just afraid to spend $160 on ONE fricken motor mount from Exhaust Depot, no matter how good it is supposed to be? What do you guys think?
· Registered
The JLM uppermount does what it says. Very effective at reducing wheel hop atleast by 90% at the track with a slight increase in vibration.
· Registered
Discussion Starter · #17 ·
How much of an increase in vibrations?
· Registered
I have all 3 motor mounts and my wheel hop is almost zero. Almost. I have the mounts from DYNOWORKS and they fit perfectly! ( I had a set of mounts from another vendor and they really sucked. The bottom one failed after a few hundred miles.. they were welded bad, they just sucked)
Also look at psi-fi's new set-up for reducing wheel hop.
http://www.srtforums.com/forums/showthread.php?t=84273&page=1&pp=15
· Registered
I just got back from the track in Vegas yesterday after installing Dynowork's upper/lower torque and trans mounts. I cut half a second off my average times and am not getting any wheel hop like I was getting in 1st and 2nd before. Idle is a lot rougher, but not any worse than other cars with full poly engine mounts. Cruising on the highway doesn't seem much different from stock. With more induction noise from an intake, these mounts, and the stock notchy shifter it's almost like driving a truck. A really fast truck. :)
1 - 20 of 23 Posts
