What kind of boost level do each stage provide on the stock turbo? Where does it bleed off at and what RPM? What is the Rev Limiter set at?
Different cars, different weather, differen boost. I doubt you'll get many responses, as there are seemingly 5 threads a day on stage 1.
Mine will hold 16 pretty regularly. No idea on bleed off and crap. I don't watch the boost gauge when I'm an WOT. It is worth every penny.
Widely available information states the rev limiter on stage 1 is the same as stage 0, stage 2 is increased.
First, Mopar's webpage doesn't say what, just saying that it raises part-throttle, WOT, and rev limit. Second, search takes to long find enough answer to get an average. Third, I did ask you to become a dick nor did I need any of your remarks about me asking the question. That is what a forum is here for, to ask questions and share information. I also notice that you are not a moderator, so why do you care if there has been hundreds of the same question asked. If you don't like seeing it, don't answer.
NoLongerStock, your right he didn't need to say that the way he did and I will change his language , but in the future please use the search function. Alot of people get frustrated when they see the same question asked multiple times. Thanks..
I have S1. By itself, doesn't raise the boost much. You need an aftermarket WGA and possibly a MBC or EBC. In 4th gear, mine hits 18 psi and drops to 15 psi at redline. I have the AGP WGA, but no MBC.
If I was a mod all hell would break loose... :eveilgrin
I care um maybe cause I like this forum and I am actually on it 8 hours a day while I am at work. (my job is boring as hell so I can work and be online at once :thumbsup: ).
Maybe I could have been nicer, but I dont care. Its a simple search. If the search sucks send ekool a message and let him know what you think should be changed to make the search better for you.
Seems to work pretty good for me and others.
Sorry if I got on your nuts and hurt your feelings, you gotta get some tough skin or you should sell your car...you drive a girls car neon that is gunna blow a head gasket in 20k miles if it doesnt rust apart before then...fuckin american cars :rofl: :jester:
Discussion Starter · #8 ·
Maybe you need a new job if you are so bored that you have to make rude comments. :crybaby: I am a member at couple other forums. I also see the same questions many times, but I don't try to answer all of them. Usually, someone will answer by the time I read it. If I do answer one, just give them the info they are asking about. Like I said before it is just easier to ask the question and see responses.
