1 - 1 of 1 Posts
ALL PRICES ARE CANADIAN!!!!!!!!
I had these all in a gauge display inside a glass cabinet. No power has ever been run to them.
$10 shipping on all of them within Canada, plus 7% tax outside of Manitoba.
Tachometers feature 5.0" diameter. Range is 0–10,000 rpm. Tachometer Signal Adapter (P4510598) required.
P4510419 Tachometer — White Face with Blue Mopar Logo
$400.00
Oil Pressure Gauges feature standard 2 1/16" diameter. Range is 0–100 psi.
P4510431 Oil Pressure Gauge — Silver Face with Black SRT Logo
$100.00 SOLD
Full Sweep Fuel Pressure Gauges feature standard 2 1/16" diameter. Range is 0–100 psi.
P4510415 Full Sweep Fuel Pressure Gauge — Carbon Face with White Mopar Logo
$310.00
Air/Fuel Ratio Gauges feature standard 2 1/16" diameter. Gauge measures your engine's air/fuel ratio from lean to rich. For 2003 and newer models, you must order the Oxygen Sensor Kit (P4510599).
P4510444 Air/Fuel Ratio Gauge — Silver Face with Black Mopar Logo
$105.00
Water Temperature Gauges feature standard 2 1/16" diameter. Range is 100°F–250°F.
P4510423 Water Temperature Gauge — White Face with Blue Mopar Logo
$75.00
Voltmeters feature standard 2 1/16" diameter. Range is 8–18 volts.
P4510433 Voltmeter — Silver Face with Black SRT Logo
$70.00 SOLD
In-Dash Tachometers feature standard 2 1/16" diameter. Range is 0–8000 rpm.
P4510446 Tachometer — Silver Face with Black Mopar Logo
$155.00
Full Sweep Nitrous Pressure Gauge features standard 2 1/16" diameter. Range is 0–1600 psi.
P4510417 Full Sweep Nitrous Pressure Gauge — Carbon Face w/ White Mopar Logo
$300.00
Boost Vacuum Gauges feature standard 2 1/16" diameter. Boost-Vacuum 30 psi/30" hg with peak warning and memory.
P4510525 Boost Vacuum Gauge — Silver Face with Black SRT Logo
$275.00
Pyrometer Kits feature standard 2 1/16" diameter. Range is 0°F–1600°F, EGT.
P4510430 Pyrometer Kit — Silver Face with Black SRT Logo
$205.00
1 - 1 of 1 Posts
