1 - 9 of 9 Posts
Hey guys did an engine swap almost finished just need this last sensor but I can’t find where to plug it in, it’s on the driver side and it’s connected to the wire where the power steering sensor is, was wondering if it’s my air fuel ratio sensor but don’t know where to plug it in to there’s a pic below
146399
hard to tell from this picture. how many wires are in the plug?
look over this diagram and see if itll answer your question for you.
146400
if it in fact is the plug for the downstream o2 sensor, the sensor will be in the exhaust behind the catalytic converter.
this was pulled straight from the service manual. If you don't have a copy, download one. You'll need it with this car....
The cat is in the down pipe... i'll take you another screen shot to show you the location of the o2 sensor...
catalytic converter
146401
General location of the downstream sensor. Located towards the rear of the cat.
146402
there is a good chance your car does not have a catalytic converter on it anymore. Many of us remove them to make more power at the expense of emissions...
1 - 9 of 9 Posts
