1 - 2 of 2 Posts
So this morning I went out started my car and it ran fine then once I started driving for about 15 miles it started misfiring and the check engine light started flashing so I changed the spark plugs and checked The wires and the coil and they are all good but still misfires any opinions on what it could be ?
I assume that you have a way to determine the misfire was on cylinder 1. The following notes are from the SRT4 FSM describing misfire conditions generally. If you are confident that your misfire is on a single cylinder, you could eliminate the possibilities that would affect all cylinders (such as low fuel pressure). Good luck hunting this down.
"If the PCM detects active engine misfire severe enough to cause catalyst damage, it flashes the MIL. At the same time the PCM also sets a Diagnostic Trouble Code (DTC).
OPERATION - NON-MONITORED CIRCUITS
The PCM does not monitor all circuits, systems and conditions that could have malfunctions causing driveability problems. However, problems with these systems may cause the PCM to store diagnostic trouble codes for other systems or components.
For example, a fuel pressure problem will not register a fault directly, but could cause a rich/lean condition or misfire. This could cause the PCM to store an oxygen sensor or misfire diagnostic trouble code. The major non-monitored circuits are listed below along with examples of failures modes that do not directly cause the PCM to set a DTC, but for a system that is monitored."
[Note to this thread: This list has been shortened to address only a misfire trouble code]
"FUEL PRESSURE
The fuel pressure regulator controls fuel system pressure. The PCM cannot detect a clogged fuel pump inlet filter, clogged in-line fuel filter, or a pinched fuel supply or return line. However, these could result in a rich or lean condition causing the PCM to store an oxygen sensor, fuel system, or misfire diagnostic trouble code.
SECONDARY IGNITION CIRCUIT
The PCM cannot detect an inoperative ignition coil, fouled or worn spark plugs, ignition cross firing, or open spark plug cables. The misfire will however, increase the oxygen content in the exhaust, deceiving the PCM in to thinking the fuel system is too lean.
CYLINDER COMPRESSION
The PCM cannot detect uneven, low, or high engine cylinder compression. Low compression lowers O2 content in the exhaust. Leading to fuel system, oxygen sensor, or misfire detection fault.
FUEL INJECTOR MECHANICAL MALFUNCTIONS
The PCM cannot determine if a fuel injector is clogged, the needle is sticking or if the wrong injector is installed. However, these could result in a rich or lean condition causing the PCM to store a diagnostic trouble code for either misfire, an oxygen sensor, or the fuel system."
1 - 2 of 2 Posts
