1 - 7 of 7 Posts
Hello,
So i have been having this issue with a misfire when hitting 15psi or more of boost. This happens at WOT in all gears. I have a 93 tune installed at the moment. I switched back to factory tune and the misfire doesnt happen at factory tune. This is only happening with 93 tune. The turbo is stock and has been rebuilt and installed 1 week ago, bfmic, and gutted cat. I have replaced the spark plugs with iridiums and gapped at .032 (brand new 4 days old). Coil and wires are granateli and were installed 4 months ago. I checked the resistance on the wires and found them to be good at .2 ohms. Yeaterday i replaced the fuel pressure regulator with a factory 58psi one. The fuel pump is a 255 walbro that was installed 4 months ago.
I dont have a A/F gauge at the moment. I did add 5% fuel at 3-4k and 5-6k and the misfire does not come on as hard. Could this be a fuel issue? After replacing the turbo the car was running really strong. After a week of driving this issue just popped up out of nowhere. After a few times of the misfire happening from test driving the check engine light would flash. Also at one point it threw a P0300. Im running out of things to check for. There have been a lot of people with similar issues and a majority of them were successful with plug, wire, and coil replacement or plug gap. Please any advice is appreciated!
Go back to stock tune. Buy a wideband. Install wideband. Do a boost leak test. Fix leaks. Fuel injectors if they have never been cleaned, good idea to have them professionally cleaned and put new orings on them. I never liked granateli wires. They would not click on my plug. But that was right when they came out years ago. Then get a custom tune. The canned 93 tune has been known to run too lean. Don't blow your shit up.
Mileage on car?
i would
1-borrow the fuel pressure gauge from autozone and tape it to the dash .. noting pressure as you do a pull (should stay at 58psi)
2-send injectors out to be cleaned !!
Mileage on car?
Mileage is 127k. Im definitely in the process in getting a widband. Car is a 2005
Discussion Starter #6
UPDATE
Issue has been fixed. Turned out to be a bad coil. I had tested multiple things before throwing money into replacement parts.
-injector pulse was consistent
-resistance of the wires were good (.2 ohms)
-spark plugs were replaced and gapped
-fuel pressure regulator was replaced
-only code that was given was P0300
Anytime at WOT the misfire would happen. This happened in all gears regardless of boost pressure. I decided to pull each plug wire while the car was on and watch the arc. There was noticeable weak spark on #1 and #4 cylinders. #4 cylinder wire would not arc at all when trying to ground it. Wires were switched with a good strong wire and the problem still exists. This definitely told me the coil was not good. Since Modern Performance is located 15 mins away from my house, the guys there helped me out and had a spare granateli coil to give. Replaced the coil and all is good now.
I hope this helps someone else who experiences this same issue.
easy enough. nice. crazy the coil was bad after only 4 months!
1 - 7 of 7 Posts
