"NIVO88T-SRTGURL'S BF"
cali said:
OK, I have never had to deal with detonation, so I cannot tell for sure.
I have a similar issue.
My issue only happens if I am in a gear too high for my speed and I floor it I get what I would call a chattering effect. I only use 93 octane.....
any ideas?
you wanna know what detonation sounds like...find a marble and a mirror, tap on the mirror with the marble fast....thats what sound you get when you get detonation....if you heard that for longer than a few seconds...oh boy....
#1 you used low octane 87,89
#2 your boost is really high and you ran lean.
but from the factory this car should take an abuse since it's compression ratio is a stock 8:1 ratio. and having forged rods and nice pistons help also.
the low 8:1 compression ratio tells me this car is made for boosting!
i bet 400hp is no problem with these internals.as long as the right fuel and fuel pressure is added. not to mention a nice turbo, wich most probably will be the mitsu family 16G large,18G,20G etc...now just imagine a nice large 20G turbo boosting 27psi and making 400+hp at the wheels!
