Has anyone deleted the metal cooalnt line that comes of the waterpump outlet and thermostat housing? Im trying to run hoses instead of the metal line cause it leaks and i have no need for it anymore since my turbo is air cooled and i deleted the oil cooler . the issue i have right now is the waterpump outlet is (i think) a 7/8 hose and i cant find a barb fitting in 7/8 to reduce down to a 5/8. if anyone has ANY input id really appricate it. thankyou!
Modern sells a coolant tube delete kit if that’s what you’re chasing. I’ve had a 513fab custom water neck made with AN fittings for the coolant lines, from there I ran AN hoses to the back of the block and it worked great
  • Like
Reactions: AlmightyFork
