1 - 3 of 3 Posts
I have the AGP WGA, set up in my car right now. I T'd off of the green line to the WGA, and did the EDTIP mod. My car is holding 16 psi to redline but I am getting 16 psi just above half throttle. Is this normal or dangerous. I get no surge just solid hold at 16 psi. The problem is I am stuck between using little to no boost by driving soft, or full boost when driving normal. Is this just the way it goes with the AGP wastegate? Any help on this would be appreciated.
my car does a basically the same thing with my Rage/Forge WGA, except my blow off valve will flutter if this happens... i am going to loosen the WGA and run a boost controller...
1 - 3 of 3 Posts
