1 - 7 of 7 Posts
So i took my car into the dealer to get the boost gauge replaced. After they returned the car to me because they dint have the part I notice this loud blowing sound coming from the turbo. Its best hurt when all the windows are closed inside the car. I dont think its a leak because there is no powerloss when i slam on it. I dont know for sure because the boost gauge is messed up so i dont know how much psi im at, but it seems fine. Anyone have any ideas what this sound might be?????? It only comes when im boosting 2.
i'd just check all ur vac. hoses
EBDBoudreaux said:
EBDBoudreaux i'd just check all ur vac. hoses
Today 08:34 AM
RedBull Check your surge valve.
x2.. what those guys said sounds like the first things u should check.
Check te hot pipe off the turbo
Discussion Starter #6
I dont have that surge valve. I put the block off plate there to install my greddy BOV. Any other ideas on wat i should check??????
First of all check all your pressure pipes, a your inlet pipe. Boost leak test will not hurt
1 - 7 of 7 Posts
