I'm looking to see if anyone has seen or had these issues. It seems to have started about 2 weeks ago and I can't locate the problem.
The issue is, when driving around say @ 30mhp and keeping just enough gas to stay at a constant rate, the car will jerk when accellerating or decelerating. I know it used to do this, but never this badly. Even with the lightest touch of gas it still will jerk. When you get on it more then 15% gass, it's fine.
My second issue started around the same time so it might be related.. It seems as if I'm loosing power. WOT is like a joke, but then again... It's getting warmer out, so I dunno. I reset the PCM but nothing.
I'm open to any ideas here.
check your TPS out. a bad TPS seems to be a common source of this kind of problem.
or
if it hasnt been doing it that long maybe you just got a bad tank of gas. use it all up (as close to empty as you can get it) and put some exxon 93 in there.
