1 - 2 of 2 Posts
Tomorrow I am hopefully going to be looking at a 2003 Neon SRT-4. It has 134k miles on the engine and body and the guy said it has a rebuilt trans with a stage 2 clutch, new transmission mounts, a 2004 ECU with a diablo trinity tune, limited slip differential from a 2005 srt-4, and its running 19 pounds of boost. He said he would take $4800 for it. Ive been looking for an SRT-4 since June and this is the cheapest and nicest looking ones I've found. Is there anything I should be looking for when I go to check it out? I know about the 3rd gear issues but hopefully that will be good since the transmissions rebuilt with lsd. I'll post some pictures so you guys can give opinions, thanks.
If it was me, i would do a compression test and a boost leak test. Another way to go, would be to take it to a local shop and have them check it out if your not comfortable enough with your own experience to make a good decision. Always look for leaks and stuff like that, see if it builds/holds boost well, the normal things when buying a boosted car. Good luck
1 - 2 of 2 Posts
