1 - 16 of 16 Posts
Iis there any how to on an alarm indicator or led scanner? I have one of those old batman looking led scanners and was wandering if it could be hooked up to a stock alarm and how. I prob just need a power wire that comes on once the alarm is activated. Any help?
Your car with stock keyless/security system should show its alarm activated. Unless of course you're wanting something that doesn't emit just at the cluster but say on the a-pillar or upper dash top?
If that's the case, you'd need to tap into the signal that feeds the stock security indicator LED in the cluster.
there's a little red light inside the gauge cluster that blinks when the factory alarm is armed. perhaps you can use that power wire.
we must of posted the same time ;) :thumbsup:
no on those scanners from what i remember there was more than just powere and ground there was 5 or 6 wires and a few different ways to wire it up and i believe on eof the way was that i twould turn on when the ignition was turned off
i have a red, black, and yellow
any way i can do this easy you think?
Nah, most are 3 wire hook-up.
Floridaboy, I'd be willing to bet you wire it up like most 3 wire scanners with that color code....
Red = 12v
yellow = switched input (alarm armed signal or ignition if you want to use it without a alarm)
black = ground
As for wiring it up, I've already mentioned how you'd do it......
Discussion Starter · #9 ·
awesome ill try that out thanxs man, Let you guys know how it was maybe do a write up or something. if anyone cares lol
I guess I will ask the question of the day then. Anyone know the wire that powers our little red dot?
Discussion Starter · #12 ·
^^ yeah what he said
Discussion Starter · #15 ·
wannasupra said:
if you eat beef, you're not supposed to have a dot.
What does that mean?
He is referring to being Indian (As in India) Look it up on Google.
By the way, found it pretty damn funny myself.!
1 - 16 of 16 Posts
