I posted this in the other section first, but couldn't addd the file... so not sure which one should be deleted. Sorry
this is my AEM EMS 60-1 750cc ems map. it runs about 14.5-15.0 out of boost and goes into boost really smooth. I am having one major drivability issue that I just don't understand.
From 1400-1600 while idling in traffic in -20 to -05 vacumm sometimes the car really surges bad. So bad that I have to clutch, rev it up and slip it to get out of that RPM range. TPS is around 5-10% approx. WBo2 is erratic while it is happening.
Any thoughts? need more info?
I tried changing the tps on/off %, DFCO rpm, turned off DFCO, changed the enterance rpms, and exit rpms... but nothing seems to make a difference.
-Garrett
EDIT: http://www.srtforums.com/forums/atta...2356.v1.19.cal
File attached
SRTforums Nazi Admin
i deleted the other thread... good luck man.
i don't know anything about the ems sorry.
I added from 2 - 5 degrees timing, and it made no difference. I think it has something to do with coming off DFCO and coming onto idle parameters... but I am not sure exactly what to change.
-Garrett
