1 - 17 of 17 Posts
SOLD!!!
Dave Trojahn
Auburn, IL
Paypal & Email [email protected]
cell two17-4one4-097nine
KW ClubSport double adjustable Coil Overs. $1400 shipped
Includes TWO sets of springs w/ helper springs
FEAL Suspensio Rebuild, Revalved and Dyno'd all 4 in August 2013{receipt provide to buyer]
They’re currently setup for around 360lb/in springs in the front and for around 325lb/in in the rear.
I was last using H&R R25080325 [325 lbs/inch) springs in front and the REAR are H&R R25080275 [275 lbs/inch) springs.[RED springs]
The original KW springs that came with the struts are Ft: KW 120-140(685lb/in) Rr: KW 70-200(400lb/in) are included as well[yellow]
how many miles did you put on them after the rebuild?
...Watching this VERY closely...
This is too damned good of a deal to overlook.
I do need these...I'm turning my NSRT into a track car.
The best price I've found on the clubsports is $2750. I was planning Mopar stage 3 coils for $1572.
I'm looking to do something on Thursday or Friday. If someone is smart, these will be gone before then.
Email sent.
Discussion Starter #11
In general yes softer springs are in fact softer but how comfortable the car rides is more dependant on the dampening. You can put a stiff damper with a "soft" stock spring and create what most would consider to be an uncomfortable ride.
These KWs even with the very stiff 685lb/in spring in the front were surprisingly reasonable. With that said, these struts were designed for track use.
1 - 17 of 17 Posts
