Anyone have this trouble before?...As soon as I replace the fuse and hit the lock button on the remote the fuse blows. This all started last night when I accidently left the lights on got out of the car and locked it. The car locked but the fuse blew and had to unlock with Key. Ever since the fuse blows immediately when I try the remote, and the rotten part is that the lock/unlock button on the driver and passenger door also gets killed because it is on the same fuse!
Thats weird.
even if you use the button on the door to lock it, it still blows?
try disconnecting the battery overnight.
its either an overcurrent draw or a wire somewhere is grounded out.
unless the keyless entry system has gone bad somewhere along the lines, thats all it could be.
Perhaps a bad lock/unlock motor?
Stupid me..just checked if it was showing code...
0633 SKIM KEY NOT PROGRAMMED IN PCM. and this means exactly what...I need to get my PCM re-programmed with the DRB to accept my keyless remote?
Turned out the remote keyless entry module was screwed. They are replacing it tomorrow. And it is covered by warranty..:clap:
