Looks like I have fallen into this problem, finally. On hi-boost the sucker collapses upon itself and I loose all boost:ben: . On low-boost it's fine though:thumbsup: Point being...where can I find a replacement 90deg. coupler? I checked ebay and they are all too short to reach the intake pipe. I looked on modern and it says it's only 4" after the 90 degree bend. I measured my K&N piece and it would have to be 6" after the bend. I'm no longer using the rest of the K&N system(just fyi) I've mated this piece up to a 3" tube(don't ask). I've tried all the local auto stores too: Autozone,orileys,advanced...and nothing! Any ideas?? I want to boost all the way!
Discussion Starter · #2 ·
Bump! Just tried a pull with the e-01 settings to off(12psi) and it still did it...With the intake off it doesn't do it. 2hsopsdherkjklsl!!!
That's only 5" on each leg...I just found a company on ebay that has one with a 6" leg...kind of pricey but I think I'm going to try it.
