1 - 2 of 2 Posts
i brought my car to get dyno'ed today and got 239 hp and 269 torque on my best run the boost was holding at around 18psi.....my current mods that would effect those numbers are probably a full 3inch exhaust with downpipe and performance cat...i also added a performance muffler cause of 2 many tickets....next is stage 2 put on my car.....also full cold air intake from the bottom on the cars wheel well....also screamin demon coil pack with plugs gapped to .040....exhaust depot hardpipe with hks blow off valve...2 motor mounts and 1 tranny mount......kept the agp wastegate....i figured my car would be at least up to 270 hp anyone have any clue to where the lost hp has gone????
post the dyno sheets.....they will tell the story for themselves.
Could be anything...some sort of boost leak.....plugs could be somewhat bad...did they put a fan in front of the car(heard some havent is reason asking), etc. Posting the dyno sheets will provide the info to answer a number of questions then you can go from there.
1 - 2 of 2 Posts
