1 - 18 of 18 Posts
Does anybody have any tips or a how to? Anything that you found that would ease the installation?
Thanks in advance! :hi:
Removing the stock cat back would be made easier with spraying down all the slip joints with some wd-40, let is sit for an hour, then removing them. You will most likely have some rust build up between the parts.
The install on the BB is quite simple. You just need some standard wrenches, and maybe a friend. I hope this helps.
YEP....thanks! Keep them coming!
Very easy install...you'll love the sound. RAW!!
Where did you order it front? I am looking for a TBE right now
AGP Turbo. The best customer service in the world!
Do you have any kind of resonating device or just a race pipe and straight exhaust?
a lift, an airgun, and a long extension is nice to have to get those dp bolts that mate up to the o2 housing
I just installed mine Sat., the hardest part is getting the stock dp off and that really isn't that hard. A little wd-40 makes it a lot easier. Its not a hard system to install at all.
Discussion Starter · #10 ·
Awesome! Keep the responses coming!
Discussion Starter · #11 ·
What size socket will I need and a min. length on the ext.?
Discussion Starter · #12 ·
:bump:
I have the catless dp, which has one resonator.
I'm havin issues getting the tips off of the friggin rubber hangers in the back :crying: . How'd any of you get it off?
Spray the rubber hangers where they connect to the car (with WD-40), wait about 5 mins and they will slide right off.
I tried that... its pulling the wider tip back out of the rubber than I can't seem to do.
Woo.. I got the friggin thing on :clap: .. Yeah it was a major pain. But ooohhhh wow. It's beautiful! :thumbsup:
1 - 18 of 18 Posts
