http://community.webshots.com/album/192152425LijauH/1
Brand new set of CUSTOM BUILT Koni Coilovers. No Koni doesn't have coilovers for the Neon in their catalog, but they will build them for you. These are for the serious enthusiats, the rod/piston has been shortened to make the car sit lower. The fronts are dual adjustable (Rebound/damping) and the rears are single adj. They have the threaded body and adjustable spring perch which allows you to adjust the height of each corner and corner weight the car. This set up allows you to run any Eibach Motorsport spring you choose to fine tune your suspension. You can't go out and buy these at any store...this is the absolute best set up you could have if you are into SOLO I, II and open track days.
Any takers? :jester:
ill slalom against u
koni inside...
