1 - 20 of 20 Posts
I just installed my IC sprayer and the love it! The fit was perfect for my factory intercooler. I did have some questions along the way and [email protected] was great with suppling help.
P.S. Thanks for the T-Shirt and stickers!
Next up Purge and Turbo Wrap!
How much did the complete kit cost to do the IC? Did you just do the intercooler?
IC sprayer
I just did the IC sprayer for now. I am going to the track tonight so I will let you know what happens.
I paid around $375 shipped.
Co2 is cheap, I paid 72 cents a pound! :clap:
I paid around $420 shipped.
Well how did you do at the track?
Im interested to hear how u did at the track b4 / after the CO2 install.
Let us know how it works out for you, I think you will be impressed.
I have ran a SRT-4 at the track with the IC sprayer on a 90+degree day and did pass after pass with no cool down or line waiting. I sprayed the IC on the return road and right before entering the staging lane and the car remained dead consistent. When the tank emptied the car heat soaked and ET's rose. Then we had the bottle filled for $10.00 :thumbsup: !
Discussion Starter · #9 ·
Well I went to the track early on Friday. I came with a full tank of CO2 and froze my intercooler before each pass ( in the staging lanes ). The car was a 10th quicker and nerver lost a beat. The car was more consistent then the driver. The bottle lasted for the 7 passes I made and ran out at a stoplight on the way home. I am very impress with the performance and I loved the attention that the kit brought my car!
nice
yea, the guys at Performance Autowerks (dave that is) told me that on the dyno they sprayed it in the middle ofa 4th gear pull and it made 30WHP!!! thats nuts!!! Also, the kit only cost $400+about $150 to install if you let a professional do it for ya. If you have a big turbo high HP, huge FMIC car its DEFINATELY recommended that you use it. Heat Soak is a b**ch
ok bigboost...your new task is to spray WHILE running down the strip and see if time is slashed.....30-40whp should make a difference I would think.
When you spray while sitting still, does it make a puddle of water under the car? I have heard that before, but tit doesnt sound feasible to me somehow.
Dusty
Anonymoose said:
You should only see a puddle of condensation thats frozen from spraying, then melted and is dripping off. The puddle would only be water.
you say ONLY WATER, but the tracks around Chicago area yell at you for dripping water...but its ok cuz if they dont notice it then I done either :lol:
Soccer69er said:
30whp sounds about right.
when i dynoed my nitrous ic sprayer...i got 33whp and 46 ft/lbs of torque.
Next time you go to the dyno, bring another bottle filled with CO2 with you. Do a pull spraying nitrous into the IC, then do a pull spraying CO2. I bet your 33whp hp gain goes mostly bye bye with CO2. Thats because your taking your dry shot of nitrous away.
you don't have to bet cause I know for a fact. check out this thread. I just dynoed my setup saturday and now have strong evidence that big gains in n20 coolers are from unmetered dry shots
http://www.srtforums.com/forums/showthread.php?t=99218
Dusty
You should not get a puddle of condensation under the vehicle unless you are over using the sprayer. Once the Intercooler is cold do not use the sprayer untill the cooling effect has disapated. This way you will use less Co2 and the bottle will last longer.
1 - 20 of 20 Posts
