i would install stage 1 if u don't wanna start throwin overboost codes and watnot. or u can do the ED tip trick to allow u to boost whatever u like. i would suggest just getting stage 1, but thats just my .02 cents.
well since the purpose of the wastegate is to boost higher and hold it longer, then i would say that yours is workin fine. i hope u put a bleed in the line since u didnt mention having a boost controller.
do a search on here, i believe there's a sticky about how to set-up the AGP WGA. I used to have one with a Turbo XS boost controller. You absolutely must have at least a bleed in the line if you're not running a boost controller.
