1 - 20 of 30 Posts
Ran a few runs today at a local dyno, the same one as AJPSRT4, my best run was 221.3WHP/252.3WTQ, second best run was 222.5WHP/245.6WTQ. I was kind of disapointed with my results considering the ATP stage 1 cat/dp thats on it. I did not have the K&N filter in,but I am guessing that would do nothing anyway.
Well, what do you think?
How can I host the graph's?
mine was in 3rd gear, and I sprayed the intercooler with water between runs.
Everybody post your ratings
Sounds good man. It would be nice to be able to see your graphs though. That would help us a little. Don't forget different dyno's give different numbers as do different days, the way the car was put on the rollers.. There are a lot of factors that come in play. I wouldn't be too disappointed.
Laters,
Steve K.
Discussion Starter · #8 ·
I have it, but dont know where to host it,........anyone?
Discussion Starter · #10 ·
Thanks AJPSRT4, I would never have figured out how to get that up there! :)
That is nothing to be ashamed of ! remember stock is 215/245.
And based on what we have seen , people put down from 207 to 223 HP in stock form.
Your best way to do it would have been to have a base run done.
Cali
Discussion Starter · #13 ·
I know, I need a good slapping for not getting a base line run, and its not like I am ashamed of it, its that I was hoping for a closer run to the 233hp/27?tq rating of ATP's run.
Oh well,....MOPAR STAGE 1, HERE I COME!!
Check ATP's car...they only got 236 with all that stuff and a boost controller set @16 PSI if I remember.
Those are pretty good numbers. Mine was at 220hp and 247tq on my first pull. The other 2 pulls were about the same. That was at about 800 miles, so it would probably be a little better now (mine are standard HP numbers, not SAE corrected BTW)
Discussion Starter · #16 ·
I just looked at there graph, 233HP/273.4TQ with MBC set to 13PSI, which my cars pulls, at least. What they dont tell you is temp at the time, and what gear they are in. Not sure if you pull in a higher gear makes a difference....
Discussion Starter · #17 ·
All I can say is between me and AJPSRT4 giving stage 1 and stage 2 runs, when he gets his car dyno'ed, you can judge for yourself if its worth the $3-400 for the upgrades.
Discussion Starter · #20 ·
You know, I thought so, and maybe it has a bit more torque, but the numbers just show the impact that I thought my ass-ometer was showing me. Its hard without another dyno on paper right in front of me, comparing when it looks like the turbo completely kicks in. In theory it stage 1 should help it spool sooner than stock.
1 - 20 of 30 Posts
