1 - 12 of 12 Posts
· Registered
Finally got my srt on fri. I noticed that if I drove it and parked it then came back an hour or 2 later that the windshield was totally fogged up on the inside. Just wondering if thats normal? Also im boosting about 12 pounds. I thought stock boost was a bit higher than that? Oh and when decelrating in 2nd gear i hear kind of a whooosh sound coming from the front end i think. and no its not the turbo lol :stab:
· Registered
i never noticed my windows fogging up. But on a new SRT-4 it taks about a thousand miles before you get full boost it it should be about 12-14 pounds. Remember that our ECU's are very sensitive to everything and will pull or give boost for the smallest differences. But the one thing it does is if you run your car reall hard all the time it will see this and mostlikely give you another pound or two. And as far as the Whooshing noise i have never heard that either
· Registered
The swoosh you're hearin might be the stock blow off valve. Do you hear it right when you let off the gas? It'll sound like someone is exhaling.
· Registered
Nope. Its when i downshift and let off the gas it goes whooosh for like a couple seconds. But only in 2nd gear. Who knows this is the first new car ive bought maybe im just paranoid cuz i love the srt so much :thumbsup:
· Registered
What I highlighted bold in your comment is exactly what a blow off valve will do. I remember in 2nd gear I'd be able to hear it but not other gears. Go out and just cruise in 2nd gear. Put on the gas and then listen really close when you let off the gas. Right when you let off you'll hear it.
· Banned
ive noticed about the window....if you let the vents open to let air in from the outside theyll fog up...thats a possibility i guess
1 - 12 of 12 Posts
