Status
Not open for further replies.
21 - 29 of 29 Posts
USMCgamer said:
What size is the opening at the TB flange because my boomba TB is 70mm. Also where would you put the map sensor if you didnt select the mount option?
The opening on the TB flange is exactly 70mm, any TB that was ment to fit on a stock intake will fit on this intake manifold.
Thanks,
Jim
Discussion Starter #23
rt2002 said:
good f n question
In the case where you wouldn't be using the stock map sensor (such as with a GM or AEM map sensor) most people would hook it up to one of the vacuum ports on the lower side of the plenum. If you're still running the stock computer and map sensor, then you'll want to select that option.
ive yet to see a pic of this intake mani installed with a throttle body and hard pipes connected...do you guys have anything...
-wes
nevermind i saw them on the website...
-wes
We also have more under the PROJECTS section of our website, under INTAKE.
Thanks,
Jim
We changed the quantity structure to allow for a discount even if 5 arent sold:
*UPDATED*Rates will be as followed:
2-4 manifolds sold; 10% off
5-10 manifolds sold; 15% off
11-15 manifolds sold; 20% off
16+ manifolds sold; 25% off
Let me know if there are any more questions.
-Jim
JM Fab
Sent you a PM
Please contact me, thanks.
21 - 29 of 29 Posts
Status
