i dont have my car with me.
just want to verify if the item circled is the camshaft position sensor 1-05093508AA.
i have P0340 and intend to replace the CPS later today.
thanks
-ayat108
Yes. Have you checked to make sure the wiring and connector haven't been damaged yet?
thanks for verifying. i have not checked the wiring yet since i wasnt sure where it is. but will this afternoon when i pickup the car from getting its brakes done. as an aside, the magnet is on backorder.
the wires looked fine up to the connector. the harness was still intact. PCM wires/connect appeared ok. swapped the CPS in 3hrs (it's really a 10min job), and took the car for a spin. test ok.
if i can make 1 or 2 gas-tanks w/o P0340 CEL then i will have verified that it's not the sensor. (battery & fuse disco could have cleared the CEL).if i still get CEL either the harness wires, pcm, or magnet is jacked up.
thx for the assist.
replaced sensor, was sure to clear magnet surface of any dust/grit from removal. was sure to use the new green band/seal. torqued about the same, sure not to overtighten. car looks to be on it's way to less than 1/4 tank and no problems.
