1 - 19 of 19 Posts
Just got the E-01 and installed it tonight. Its new and does it have a new option???
I get to select Speed in a few different areas for options and settings. One is in the Boost setting. Theres Hi, Low, Off, And Speed? Then in the display theres all the reg I guess as well as Specificly Speed. theres also a Preset map/equation to set speed measurement in the settings?
Could this be a new unit and the way the new ones come? My box only shows Hi, Low and off even....
never seen a speed option. there's some mention of speed here and there when connecting a speed sensor to one of the pulsed inputs... other than that...
well what are your firmware versions?
Well It brand new, just got it yesterday, here this screen:
Well it also has a "Speed" option to select. Anyone else have this?
How do I check the "firmware"
well here are a few picts that are not all that good but its a green screen at night in a car, sorry. the one is of a "Speed" adjust screen with three settings, one for Off, one for Low adn one for Hi, All three are adjustable for what speed one sets?
Then the next is of the three PLUS Speed options when setting boost setting to either, Off, low, Hi, Or Speed?//
Anyone else???
this is what i have been trying to figure out for a month but every keeps telling me no it cant be done if you figure it out be sure to tell us
Well:
E-01,
Display unit - 1.10
Center unit - 1.11
so maybe that explains it?
next time i get out to my car i will check my versions. if yours is newer... oh boy... i'm gonna need to borrow your sd card!
Discussion Starter · #9 ·
ok got a very cool email from a very good source on the Emanage/E01..
Robert,
I just checked one of my new units and it have what you described, so its new...cool option....
you will get the speed option working once you get the e-01 signal harness and hook it up to your ecu speed wire, then it will work...
Mohd A.
www.mohdparts.com, The E-manage & E-01 Source!
So I withdraw my how to make it speed sensitive since now it is... :readclose
that is very, very cool. speed based boost is going to be a great feature. i hope there will be a way to upgrade.
how possible would it be for me to borrow your sd card?? i'm pretty sure the firmware is on there and a quick flash and sha-zam.
Discussion Starter · #11 ·
Well you drive here to so cali adn your welcome to it.. lol I think theres a way to upload the file to to a desktop? then just email it to ya? I have a call in to greddy adn they are to get right back to me about this. Their specialist in the e01 is not in yet.
What versions are you currently running and Does that SD card hold the complete E01 software package?
not sure on the versions, won't have a chance to check till like... 5pm or so. i've tried reading the card using a pocket pc and got nowhere, unknown format. hopefully someone will know a way to get it onto the card, perhaps when you talk to greddy you might get somewhere.
thanks man
Discussion Starter · #13 ·
Well I can pull off what ever is on there to my desktop adn then email it to you, BUT you would need to replace your files on your card somehow.. One way would be to get a SD reader for your PC (their cheap!) AND REPLACE THEM THAT WAY,BUT I HAVE NO EXPERIENCE WITH THE SD FILES/DATA SO THAT IS ONLY A GUESS..
I will ask Greddy when I talk to them again later.
wow this will be another amazing feature on profece01 .... im on pins and needles to hear the news
I have this speed option on mine as well. There is a spot somewhere to select the input source from either pulse input 1 or 2 which means you'll need the optional input harness.
I also noticed that it isnt really clear as to wether or not its going to work. When you select the speed option on the boost set screen, then flip back to the display mode, nothing is different, it still has the same HI and LO boost modes off to the right.
Anyway, I dont think this feature will be much good for me anyway. I have the AGP 50 trim, I just got it running yesterday and as of today, Ive worked my way up to 17psi and when I go WOT in 2nd gear, at about 4k rpm the tires go up in smoke! So.....if I were to setup speed boost and spin my tires in 2nd (which makes the speedo jump) it would probably trigger hi boost and make things that much worse!
not if you keep the boost low enough. for instance if 2nd @ 4500rpms is 50 keep the boost *somewhat* low till 50 then bring it on. heh well it might work anyways, so are you anywhere closer to ohio? (need someone with a sd card with this firmware!)
1 - 19 of 19 Posts
