1 - 2 of 2 Posts
Is it possible to use two, two channel amps on one set of component speakers? I have one set of higher powered speakers and two amps that are not enough to power them individually. I do not want to buy another amp if I don't have to.
Suggestions?
you have 2 relatively easy options:
1) if they are identical amps, bridge each one and have one power the left side and one power the right side.
2) if they are not identical, or you just want to go with an active x-over, use the higher powered amp for the mid-bass/range and the lower powered amp for the tweeters.
option 3 would be if the passive x-overs have built in bi-amping capabilities.
1 - 2 of 2 Posts
