1 - 11 of 11 Posts
Any help would be appreciated. I have a 04 Srt4 that is stage2, with a AGP wastegate, everything else is stock on the car. When I bought the car it came with a DSP intune and the previous owner said he never had a issue with it linking to the car. I plug in the dsp cord to my ob2 port and then to the tuner and it powers up just fine. But when the tuner prompts me to click my key twice so the accessories comes on, it just shoots me a generic error code that it could not connect. I called DSP about the issue and they advised I need to try it on another srt to see if its a issue with the tuner or my car, which I did, and it pulled up just fine on another srt. But when I plug in a code reader into my ob2 port it works just fine as well so I'm a little puzzled as to why another code reader will work but my intune wont. Any suggestions?
I also had some error codes when installing tune using intune.
My solution was:
Keep the doors closed and put seat belt on
Discussion Starter #6
Ok update, i have checked that i do not have any bent pins on both pcm plugs and ds plug pins.
I also do not have a turbo timer on the car, and i tried the whole keep door closed and put seat belt on lol and that didn't work.
I have a friend that has a trinity turner and i plugged that into my srt and it pulled up all my info just fine, was able to clear codes, monitor the vehicles rpm, fuel maps etc...
So im not sure whats going on, why my tuner will just not work on my car but works on hers and her tuner works just fine on my car as well.. Im baffled
Discussion Starter #8
Yea i could try that, but i would hate to order a cord and it still not work and ive wasted money ya know!
Discussion Starter #10
What do you mean by dont use a flash programmer? have a standalone?
And the trinity connector is different from the I1000 connector other wise i would
I don't use a flash programmer in my car, I run a system similar to AEM, Haltech etc.
That is why I asked about the cable.
1 - 11 of 11 Posts
