1 - 3 of 3 Posts
Hey Scottmech, I was hoping you could help me out with a few questions. I am looking at getting your downpipe w/ cat or possibly the interchangable downpipe. I go to the track frequently and I was wondering if getting the highflow cat would be sufficient or if I should opt for the available interchangable dp? I have to have a cat since I live in california so a straight race pipe will not work for me. I like the idea of changing between the two options but is the power significant enough to worry about it? Can I do this at the track with a jack, and how much of a pain is it to change out? Will it have a tendency to be more prone to leaks than getting the system w/ the highflow cat welded in? I hope you can answer these questions for me as it would be most appreciated. Thanks in advance and I look forward to a response. Anyone else on the forums viewing this feel free to chime in as well with your thoughts.
Well I can't say specifically to Scott’s downpipe, but I can say for DP’s in general. I own the atp DP and I started with the race pipe and it was just stupid load, with B&B exhaust. I then bought the cat for it and have never gone back to the race pipe. I think most people are seeing very little power gains from using a race pipe with the stock turbo. This is even more so with Scott’s DP since he uses a very nice cat.
If your not using the stock exhaust or a muffled exhaust you should keep in mind that most NHRA/NDRA tracks are requiring some type of muffling device on cars now.
Depends on what you want to do.
The interchangeable dp is more designed for the annual trip to the smog station. I would not reccomend it for removal of the cat every weekend at the track. Removal of the cat with slip joints is a little more effort than the v-band style joint. Most people buying them have the race pipe installed, then install the cat for emissons, but I didn't say that................
Any system with more joints will be more prone to leaking, I'd be lying if I didn't say otherwise. I've had my interchangeable pipe on for 4 months, with several 750 mile trips, several 12.2 quarter mile runs with no leakage issues. There has been only one reported leak, becuase I expanded the pipe too much. I immediatly made him a new one, and fixed the problem.
Since you live in CA, I'd reccomend the welded in cat. I don't think the hp difference will be that much you'll feel it on the street.
1 - 3 of 3 Posts
