1 - 15 of 15 Posts
and in third gear WOT run it reads 10.2- 10.4.....is that good or bad...i honestly dont know...ive searched and im clueless...its about 14.7-15.4-5 at idle......Btw i have a clamp(dasmopar), but its not put in yet cause i have no idea how to do it, and what to look for....Help would be much apreciated...thnx
The SRT from the factory runs pig rich at WOT for reasons being its safer to be richer than leaner.. the fact that its around 10.2 - 10.4 shows how much more power can be made with a fuel controller like the SAFC-II Neo or a complete stand alone engine management system such as the AEM unit. The car is happiest with a A/F ratio of around 11.8 - 12.0 at WOT which is considerably leaner.
As for your clamp, a simple search on the forum will net you at least 2 pages of poeple throwing on MAP clamps for their SRT's.
make note you need to take pcm off boost control....such as agp wga .....before you tune with mapclamp....10s on the afr is pig ass rich
:eeeek: The scary part about that, is that i already have an agp wga..its set @ 17-18. In case it matters i also have stage 1 , needswings dp v5 and an intake... Any Ideas guys?
i knew 10.2 wasnt a good number
BLKDOUTSRT4 said:
10.2 is great.....cant fuck up your car at that afr nice and safe...check your boost gauge and make shure it is accurate
thats good to know..:clap: im going to attempt the clamp install 2morrow hopefully everything will b ok....if i set it to lets say 12ish afr..can that allow me to raise my boost up a bit? And also what can i expect from setting to 12ish in terms of performance..will i notice anything?
Btw .. I really apreciate the input...:thumbsup:
oh i dunno about that, ya rich is way better than lean but if you go too rich you will get fuel blowby pass the rings and get a saturated crankcase. for the best power 11.8-12.5afr and if you are worried about emissions, run it lean.
10s are pretty common for the srt-4 ...i was in the 10s stage 2 and im in the 10s now with stage 3
running it lean will help the emissions a bunch cause the shit will be blowed up and not running and we all know a non running blowed up car has 0 emissions...
Discussion Starter · #10 ·
so i should leave it at 10.3-6? or lean it out to 12ish? wouldnt leaning it a bit crank out some more ponies? I want ponies!!:eveilgrin
leaning it out gets rid of some popping noises too lol
Lean it out to 11.8. You'll be fine.
I agree. Anywhere between 11.6 and 11.8 is perfect. If you throw in some race gas for running at the track, then you can tune it to 12.2 to 12.4. Add W/I and you can tune it even higher.
Sorry for thread jacking but...
If you install a fuel controller, can it be uninstalled fairly quickly? and what traces would be left behind that it was there? just a few spliced wires?
1 - 15 of 15 Posts
