Original Owner '05 SRT-4 S2 Toys
I need to know which filter the kits came with- either the 30um or the 100um. I don't really want to remove the fascia on my SRT to find out. Thanks in advance.
I don't remember any stainless mesh filter.
Which component are you asking about?
"Turbo Toys" by itself is a bit nebulous.
I'm referring to the "cheese wheel"-shaped filter, circular black plastic. This is part of the intercooler sprayers.
After your response, I edited the title of this thread to make it more clear.
Perhaps this?
P4510626 Inline Water Filter 29.00
This is from the Replacement Parts List.
But it doesn't include any specifications.
Here's the complete Replacement Parts List in case you or anyone else needs it:
The format isn't great.
But at least the Part Numbers are visible.
I ran a quick Google but this particular part seems to not be available anymore.
I did see someone selling one on Ebay but buyer beware as always:
Alternatively, maybe you can just blow your out with an air compressor?
But you will be removing the fascia to get at it...
Good luck.
EDIT
ps
Maybe Cooling Mist has something that will work for you...
-------------------------------------------------------The Replacement Parts List-------------------------------------------------------
Thanks to the MOPAR crew, here is the Turbo Kit replacement parts listing - hot off the presses.
Take Note: The parts are NOT available yet... Dealers have not been sent this info yet either, so don't expect them to know anything about this yet.
The vendors must build enough parts to support kit orders as the immediate priority, so the parts will become available in the near future. If you are dead in the water, call the MOPAR help line.
They provided this info on the forums as a favor to those that have been waiting patiently. Please understand that this is an initial list of parts.... If you want to see some more, then post your requests here.
Part Number Description MSRP
04546692 O-Ring Fuel Pump Mod 8.35
04852396AB Copper Washers (6) 2.35
04884447AA Gasket 9.75
P4510063 Fuel Rail Assembly, Demand Regulated 279.00
P4510365 Sensor, MAP 3.0 Bar 80.00
P4510366 Sensor, TIP 3.0 Bar 110.00
P4510529 +30% Fuel Injectors (Individual) 89.00
P4510554 Fuel Pump Module, High Flow, 75PSI, Demand Regulated 699.00
P4510595 Wastegate Actuator (P350) 129.00
P4510596 Wastegate Actuator, Stage 3, (P420) 289.00
P4510601 Bezel Assembly 199.00
P4510623 4-Way Connector 24.00
P4510627 Inline Check Valve 35.00
P4510632 Sprayer Pump 60.00
P4510659 TD05HR Turbo with Inconel Steel Wheel, IncludesTurbocharger (P4510279) and Elbow (P4510278) 1,799.00
P4510861 Terminals (wire harness), 1 Pkg = 10 pcs. 10.00
P4510862 Blue LED (wire harness) 4.00
P4510863 Red LED (wire harness) 4.00
P4510864 Turbo Cartridge, Iconel Turbine Wheel 750.00
P4510865 Turbo Cartridge, TiAl Turbine Wheel 1,650.00
P4510866 Turbo Hardware Kit: V-Clamp, Compressor Snap Ring, Actuactor Clip, Actuactor Bolts, and Elbow Bolts (5) 120.00
P4510867 Compressor Kit: Compressor Cover, Surge Bypass Valve, & Surge Valve Bolts (3) 225.00
P4510868 BOV Diaphragm 67.00
P4510869 Manifold Kit, Turbo Exhaust Elbow (P4510278), Manifold (P4510877), Elbow Bolts (5) 1,350.00
P4510922 Sprayer Brackets, Set of Two (2) 25.00
P4510923 Water Jets, Set of Four (4) 129.00
P4532586 +40% Fuel Injectors (Individual) 39.00[/QUOTE]
Discussion Starter · #5 · (Edited)
I already had that part number but thanks anyway. I really need to find out if that part is 30um or 100um- perhaps it is molded into the black plastic? I didn't save the bag that mine came in and can't remember if it was marked in some way to distinguish which one it is. I've called both the Mopar Direct Connection Tech line and Modern Performance and neither one knew the answer.
I found the part! JEGS had one listed on their website so I took a chance that they might be able to get it. I had already called the Mopar Direct Connection Techline and was told that the Centerline PDC had two in stock so I relayed that information to JEGS. The part just now arrived- according to the the part bag, P4510626 is an Aquamist Inline Stainless Steel Mesh Filter (Low Pressure), 806-257, 100um. Mystery solved!
you can backflush it, also the nozzles disassemble for cleaning.
Discussion Starter · #8 ·
Thanks- I figured that. I thought that it would be a good idea to have extra parts though, just in case.
