coolingmist >*
murrtownsrt said:devils own ftw, my buddy ordered a coolingmist kit and he was missing alot of shit. we had to go seaching for parts :gay:
It sounds like you would want an on/off style standard kit. Our versions of the kits are easy to install and as reliable as you will find. In our version, there is a boost switch that has adjustments from 1-25 psi, you set it to turn on at a specific boost, when you are at or above that boost it will inject. Its very effective and just what you need.ppx said:im in the market for a really good w/i kit. something that can be reliable. i am on a 50 trim and built head with cams. just want that extra boost and lower knock on pumpgas. any got any kits or companys that can give me some info on thier kits? im still new to w/i and wanna learn about it before i go about running it on my car. thanks in advance.
vendors welcome to chime in and offer thier .2 cents please!
1 more thing, im looking at running 100% pure meth through it as well
This $199.95 price will stay on this kit for the time being. The trunkmount kit is on sale for $299.95, that kit is usually $359.95 and will go back to regular price shortly.ppx said:would you be able to keep the 199$ price till june 28th when i get my next check?
RiVal said:Sup Ppx!! Sorry ta high jack ur post. but I'm startin ta be very intrested in W/I ... I want ta runn high boost without alwayz runnin 1OOoct. Gets pricy after a while and I don't run it on the street so really 1OOoct is all Show.
My Mods are in sig. Mike said his Coolinmist W/I is the way ta go. Hey Christian help a Brotha Out. Wich one I see 2 diff ones?? 2OO sounds good ta me tho.
So question is I wanta run pump gas 18-19psi with O Kr, and 22psi on 1OOoct with O Kr is this the Kit for Me??
I will do more research while I wait for me ta make up my mind
Hey man,christian! said:i run 21-22psi w/ 0KR.
its all in the tune tho. i run my car some what 'rich' regardless of if its just straight meth, or if its meth and 110oct.
if you have questions, drop me a pm.
Right on mike thanx fer the reply.christian! said:RiVal said:Sup Ppx!! Sorry ta high jack ur post. but I'm startin ta be very intrested in W/I ... I want ta runn high boost without alwayz runnin 1OOoct. Gets pricy after a while and I don't run it on the street so really 1OOoct is all Show.
rival, send me a pm.
i actually have a devils own meth kit.
almost all kits out are 100% identical aside frm the check valves.
i have had 2 check valves fail on me from devils own, and 1 from coolingmist.
CM sent me an updated check valve, and it works flawlessly.
cant say anything bad about DO tho. because they warrantied their check valves as well as sent me a free meth filter.
RiVal said:Right on mike thanx fer the reply.christian! said:RiVal said:Sup Ppx!! Sorry ta high jack ur post. but I'm startin ta be very intrested in W/I ... I want ta runn high boost without alwayz runnin 1OOoct. Gets pricy after a while and I don't run it on the street so really 1OOoct is all Show.
I'm actualy lookin at the CM 169or 199 kit. I like there selinoid CV.
how much more lean can u go on 91oct than the usual 11.5?? And how much more lean can u go on 1OOoct runnin 1OOmeth?? What afr's do u tune at?
ohhhh.christian! said:175. i run a m5nozzle w/ straight meth. around 320hp
