for you nitrous users, do you leave your bottle on all the time, or turn it closed everytime you shut the car off?
for those using ic sprayer systems...either nitrous, carbon dioxide, or water, when you manually use it. do you use it before a track run...or constantly until the end of the quarter?
I close the bottle and purge the line when I'm done using it.. It's probably not good to leave it on all the time because if it gets hot out, all the pressure in the line is going to increase and anything over like 1100psi is bad on the solenoids..
i just thought of something... most likely i am not the only person whom thought of it..
but anyway... if you are using nitrous for a IC chiller.. could you tape into the same line for a shot of nitro... so when you hit the nitrous it kicks onthe IC sprayer at the same time...
